1 - 9 of 9 Posts
· Registered
On my way back to the office during lunch and saw that both the ABS and ESC lights came on at the same time. First thought I had hit the ESC button and pressed it. Nothing happened. Car seems to be running fine. Got back here, turned off the ignition and turned it back on. The two lights didn't come back on. But I didn't drive or brake, so don't know if that was a test of any kind.
So, what's wrong with the car?
The front brake pads and rotors were turned a few months ago. The brakes have had an occassional squeek since, which is another issue. Rolling eyes.
Thanks.
· Registered
QUOTE (Suzanna @ Jul 26 2010, 10:15 AM) index.php?act=findpost&pid=344880
Thanks.
actually there is a recall for that
its called stop brake lamp switch recall
mine had the same exact problem and after going in to dealer for that recall
it fixed the problem and i get that squeek on my brake also and it kind annoys me :(
· Registered
QUOTE (Koolguyv33 @ Jul 26 2010, 01:30 PM) index.php?act=findpost&pid=344885
When was the recall? I go to the dealer for all the oil changes, service, etc. (see my headlight bult thread).
They check every time and said I was up to date on all recalls.
And that affects the ESC light too?
· Registered
Have I not run your VIN for recall & warranty calaims history ?
· Registered
Tell you if your car is up to date or not, review past warranty claims to see where you are with common problems..
I'm walking out the back door here right after I submit this post, be home in approx 45 minutes, but will not have access to WEBDCS until morning.
· Registered
QUOTE (sbr711 @ Jul 26 2010, 05:09 PM) index.php?act=findpost&pid=344960
Is this something I PM you? I understand the advantages.
Especially since I don't know you. I haven't been around much the last couple of years.
· Registered
QUOTE (Suzanna @ Jul 26 2010, 05:24 PM) index.php?act=findpost&pid=344962
Yes, PM the VIN.
DO NOT post VIN in public forum... I should have very good references, you can ask moderator "lovemysantafe", and many other here of which I have run VIN for warranty info and recalls, along with people at hyundaiforum site, and the yuku hyundaisantafe site.
I do not keep list of names, I get the print, pass relative on to owner, and I am done.
Let me know if I can run your VIN and advise you to what I find.
Yes, I am a Hyundai dealer technician..
· Registered
Discussion Starter · #9 ·
QUOTE (sbr711 @ Jul 26 2010, 07:20 PM) index.php?act=findpost&pid=345009
Yes, PM the VIN.
Will get the number off the dash in the morning. It's dark now.
Appreciate your help.
By the way, the lights didn't come back on.
Eratic problems are most irritating.
Where are you located?
1 - 9 of 9 Posts
