1 - 20 of 24 Posts
‘22 Tucson Limited PHEV, Deep Sea Blue & Charcoal
I have a new issue that seems to be getting worse. On acceleration from stop, the first two or three stops after starting the car, I get a very deep resonant groan, almost like a vibration, but it's not a physical vibration. Like something electrical, especially loud if the radio is on but still audible with the radio off.
  • Wow
Reactions: BSparks294
You say it is louder with the radio ON? Is the sound actually coming through the speakers at all?
At first I thought so but I turned the radio off and still heard it, just not as loud. It’s like a deep boing…
Just a guess, but sometimes the power amp for the radio stays powered up even with the radio switched off. See if you can hear the sound coming from the power amp under the seat.
How would that explain the boing on acceleration only at the first two or three stop and goes of each trip?
No idea. Just guessing, based on the noise being LOUDER with the radio on. Absent the radio symptom, and the noise clearing after the first couple of stops, I would look at the parking brake system. Do you use your parking brake regularly? If so, try leaving the parking brake off, (as long as you park on a relatively flat surface) and see if you get the same noise. Regardless, If it is getting worse, I suggest trying to get a recording of the noise before you bring it in for service. Good luck.
I never manually apply the parking brake.
  • Like
Reactions: mungo544
Discussion Starter · #8 · (Edited)
It is progressively getting louder and occurring more frequently. It seems like it's more prevalent if I'm also turning on acceleration, like pulling out into an intersection while turning. I scheduled a service visit for next week to look at this, my battery dying, and the black box behind the rearview mirror constantly opening at the slightest bump. The service writer was perplexed when I predicted none of it will be resolved...
Then my cousin tells me her 22 ICE Tucson has an issue where the accelerator doesn't disengage so the engine revs even with her foot off the gas. The service gy told her "it's not a problem". Yikes.... Right up to when she rear ends someone because the car kept accelerating on its own. I'm starting to wonder what I've done....
My advice take it in to the dealer if its under warranty. Let them sort this out
That's about the time the ABS does a self test.
Temporarily pull the ABS fuses and see if it goes away.
Discussion Starter · #12 ·
Well that's interesting. Every time you start up from stop it self tests?
2022 Tucson Limited Hybrid, Quartz White
No, it should only do it once after first starting and driving the car. Some other ideas based on other threads I’ve read:
  • Bad wheel bearings
  • Faulty transmission
  • AWD transfer case issue
People are reporting similar issues as you…noise that got louder, especially during a turn. Humming sounds. Car seems like it doesn’t want to shift out of first gear. But best bet is to have the dealer take a look at it. Hope you can get this fixed soon.
Discussion Starter · #14 ·
It’s more like a boing. Only lasts a second. But now it’s each start from stop.
Do you ever use auto hold? If not, try turning on auto hold and see if you get the same noise. If it goes away or changes it in any way that may narrow it down to something with the braking system. (stuck caliper, defective brake hose, etc.)
Discussion Starter · #16 ·
A stuck caliper would be pretty obvious, no? Remember, this is not coming to a stop, but starting back up. I will try auto hold, or whatever it’s called. I only don’t use it because you have to manually turn it on every trip.
Since the boing sound has increased in frequency....
Dealer item to diagnose. Let us know their opinion on the fix.
Discussion Starter · #18 ·
It's going in Wednesday. I don't expect to hear anything other than, "We don't hear anything wrong".
If the caliper is not releasing completely on one side the brake pad could be dragging creating a groan or boing sound as it fully releases. Some of the Hyundai cars have a brake caliper that has sliding parts and a slight rust build up can cause the caliper to hang up and not release properly when coming off of braking as when you are starting to getting going again. If it happens only when turning left it could be a caliper on the left. If it is happening when turning right it could be a caliper on the right hand side of the car.
If it is none of these things maybe you have a gremlin or a mischievous spirit living in your car's machinery.
Discussion Starter · #20 ·
Turning in either direction. The car hasn’t even been wet except for touchless car washes.
My money is on gremlins…
1 - 20 of 24 Posts
