1 - 13 of 13 Posts
I believe that my 2012 Elantra's air conditioning has failed. Although it is getting cold out (54 deg F this morn), it feels like it should be getting colder coming out of the vents. I visually verified that when I turn the A/C on in the cabin, the clutch on the compressor locks up.
But there is a possible complication: I noticed a few days earlier, that the airbag warning symbol came on and stayed on while driving. According to the manual, this indicates a nebulous failure somewhere in the airbag system. A few days later, it went off, cam back on a day later.....
Could this airbag light be possibly connected in some weird way with the A/C crapping out? What are some things to look for with the A/C failure? Obviously there could be a leak, but it went out suddenly. Any help is much appreciated......
Cabin filter, I believe the last time I changed the oil - within the last 6 months.
If the ambient temperature is under 65*F it will not command pressure.
WHAT!
No, that can't be right.
I just checked, it wont command pressure when the ambient temp is below 2*C (35*F), not the 18*C that you were suggesting.
What makes sense. AC on at 40* or off?
Who is right? Well, I think ^^ that ^^ is a pretty good clue.
In your logic it would be running at 40F but I'm not trying to split hairs. I see I gave the wrong number at 65 it say's 55 in alldata.
At any rate, If he had a IR thermometer he could find out the actual numbers.
Discussion Starter #11
Took it to a local garage. They charged it up. They say the pressure is about the same on both sides of the compressor implying the compressor is shot and needs replacing. Is there a credible compressor failure mode that also involves a leak? This sounds like it will be $$$.....
1 - 13 of 13 Posts
