1 - 1 of 1 Posts
I have a 99 Auto Excel "Sportz" with 126,000 on the clock.
It's literally a car from a little old lady and is in good condition all round, totally original.
The transmission is misbehaving, when I'm coasting in drive below 40kph and then accelerate it shifts into 1st gear.
Also when at higher speeds, again when coasting it will shift out of OD for no apparent reason.
All gears work and mostly shift normally- apart from the 2 faults above.
Seems like an electronic problem, not mechanical to me
Where should I start looking to fix this?
TCM? CPS? TPS?
Does the transmission need to be over hauled?
I might add it ocassionally shows a CEL, I've tried 2 different OBD scanners and neither will connect.
Cheers
Michael.
1 - 1 of 1 Posts
