any help...my 96 elantra riugh idles and bucks when I slow down it also stalls when slowing down and turning corners....it sounds like it is gasping for air
The gas filter, plugs, wires, air filter haseen changed...My guess is that it needs a oxygen sensor...has anyone had this problem before. I heard the oxygen sensor could cause this
The best thing that I can suggest for you at the moment is to take your car to a service centre and have your codes checked.
Unless you can give us a more detailed description of what's actually going on. then the above procedure would be the best answer!
