hey guys
i know cars fairly well i convert nissan cars engines all the time but know NOTHING about excells so just need a little help
my little sisters 95 12v excell (aus) has the auto gbox starting to pack up *jumps outa gear, doesnt engage sometimes, reverse takes ages ect.* the good news is a relative just got her excell rear ended so i have a 98 16v excell with all the donor parts! (have not looked at the 2 cars side by side yet so some q's very simple)
firstly i think just changing gbox will be simplest task IF it bolts to this engine so will it?
if it bolts to the engine will it bolt to the chassis?
if it will then im assuming i will need to change the pedal box over, the gear selector cables, clutch & flywheel, and loop the auto safety switch, but will i need to swap over ecu's ? anything i missed?
If it wont bolt up will the 16v go into the bay without mods? or is it just easier to change over the whole front end *xmember suspension loom ect*
any other bits that might catch me out? Just wanna get it done asap for her as she will need it back on the road asap
