I bought a brake switch as a spare a couple of years ago after recall replacement. Didn't realize the kind dealer sold me the recalled 93810-3S000 switch. I jerry-rigged this plastic cap quarter turn don't put the nut on 180* off or you cannot push in the locking tab POS.
At least it starts & at night I can situate the rod on the pedal & turn off the brake lights. I'm going to order a couple of the 93810-3SR0A-QQH switches. I also need a couple of the small rubber bumper pads that adhere to the brake arm for the brake swith plunger to rest upon.
Then again maybe I don't. The old one was worn all the way through and I had to peal it off installing the NOS old switch as a stop-gap temporary solution at 2:30 AM.
Is there a part number for the small rubber pad?
I wish to add that after the recall switch was replaced, around 32K, I've had to adjust it twice w/third need unable to adjust at 58K.
That recall switch lasted a whole 26K w/as mentioned two seperate adjustments to stop the brake lights from always on.
Thanks
Thanks
