Hey guys, i was a proud new owner of a 1990 hyundai Scoupe up until a few days ago when she sprung a leak!,
it's leaking water, rapidly now, i jacked it up today to take a look, and the Water pump is situated horribly,
but i can see the leak is coming from a small hole about the size of a matchhead beneath the actual waterpump,
the hole looks machined, rather than caused by corrosion,
I'm just wondering if anyone has any advice as to what my next step should be, before i start taking all the belt's off! :grin:
i can get a photo of it tomorrow morning and post it up, if that helps
you will need to take the timing belt off to change the water pump, change the belt at the same time
thanks for the speedy reply :)
i'm not really sure if installing a new waterpump is necessary, as i don't think the impeller has deteriorated,
and i took a closer leak at the hole from where the water is leaking, and it seems from the rust around the area that
it's had a slow leak for a while,
Thanks for the help mate,
i'll get to fixing that up in the morning,
great forum you've got running here
but i have one more (possibly silly) question left!
is there anywhere that you know of that i can get my hands on a PDF
version of the manual for the Scoupe?
Nvm, i found it,
again, thanks for the help!
