hi, new to the forum and wondered if anyone has encountered a leak in the clutch system? Its proving very difficult to change gear. I think I have found where the leak is but unsure of what the part is or even if it can be replaced.
451020
hi, new to the forum and wondered if anyone has encountered a leak in the clutch system? Its proving very difficult to change gear. I think I have found where the leak is but unsure of what the part is or even if it can be replaced. View attachment 451020
Wich type of Hyundai is this?
I need to found where is locate the slave cylinder on my I40 2015 manual gearbox.
The slave cylinder is inside the bell housing which means removing the gearbox to get to it. My question is has someone recently worked on the car and tried to bleed the clutch hydraulics? The leaked fluid I see may have come from the bleed nipple.
