1 - 11 of 11 Posts
2002 Elantra GT
2.0 Liter engine
5 speed manual transmission with pull type clutch.
Is there a 6 speed manual out there that will bolt in (newer Hyundai, Kia, Mitsubishi)?
I'm going to need a new transmission sooner of later and thought, why not ask?
I have no idea of the transmission to engine bolt patterns.
I do not know and I feel it would be a problem as current engine is 1.8 and completely different design. Plus tranny is six speed with different mounts.
Well, thank you for responding.
I will need to replace it some day and believe there are other options as Hyundai, Kia and Mitsubishi used a lot of commonly designed parts and was wanting to do something interesting/different.
why do you want to put 6 speed?
do you feel 5th is too short? Maybe try 5spd from HD. It is same engine, as far as I can tell mounts look same, but the 5th gear is taller.
If it were a simple bolt it, why not be unique.
Also looking for a taller set of gears.
Where did you get the gear ratios from?
OK, follow it...
2002 > G 2.0 DOHC
Engine Mechanical System [Print]
Fuel System [Print]
Body (Interior & Exterior) [Print]
Body Electrical System [Print]
Brake Systems [Print]
Clutch System [Print]
Drive Shaft & Axle [Print]
Emissions Control System [Print]
Engine Electrical System [Print]
Heating, Ventilation & Air Conditioning [Print]
Restraints [Print]
Steering System [Print]
Suspension System [Print]
Transaxle/Transmission [Print]
>Automatic Transaxle System
>General
>Manual Transaxle System
>>General
>>>SERVICE ADJUSTMENT PROCEDURES
>>>SPECIAL TOOLS
>>>SPECIFICATIONS (M/T)
>>Manual Transaxle
>>Manual Transaxle Shift Control
>>Shift Lever Assembly
>>Troubleshooting
>Troubleshooting
Discussion Starter · #11 ·
And PLP touches the switch on the light.....CLICK!
Thank you.
It took me a couple of times toggling back and forth but got it now.
I was not looking in the right folder.
1 - 11 of 11 Posts
