1 - 11 of 11 Posts
245 65 17 method race wheels and Nitto terra grapplers G2. Installation of the lift was farly simple. Bought it on amazon. Happy with the finished look.
Lift is nice, wheels and tires do nothing for me on the plus side...but I'm old so...
Yes, its a credible company.
Anytime you change tire size, you screw up the speedometer. You will be going ~7% faster than what the speedometer says if it was accurate. Since the speedometer is usually a few % optimistic, you're probably going ~4-5% faster. That is nothing that someone with 1/2 a brain couldn't figure out and adjust for.
I think it looks great. Not over the top lift just enough to give it a functional look for light off road instead of another family utility vehicle
Good modification.
Its awesome to see another lifted tucson =D Great looking rig. Do you go on any trails or light offroading?
Im curious, have you run into any rubbing issues while steering? With a 40mm lift and 265/60r18 I get a bit of rubbing. I was thinking of installing some different springs to lift it a little more to help clear the tires but i had the kit installed at a shop because the rear springs. How did you get those off?
1 - 11 of 11 Posts
