Hey there everyone, I’m looking into some 20mm wheel spacers for my 09 Accent. I’m running a set of stock size 14 inch Drag DR-34’s with hub centric rings. Will I have any clearance issues with running a 20mm spacer on the front and rear? should I do a smaller size? I’ve found some spacers for a Miata that Amazon says will fit.( https://www.amazon.com/dp/B01M03MYMN/ref=cm_sw_r_cp_api_O0HFBb9CZV69S ) Please advise!
Discussion Starter #2
An addendum to this post: I’m looking to make my wheels flush, without rubbing on spring compression (I live in a spot with very rough roads). I’m on stock ride height, and I read on an older thread that 15mm in the front and 30mm in the back will give me the flush look, is this true?
