Hi all, can someone please advise if they have had the same problem we have with our 2007 Elantra popping out of gear under load. The car started doing this at about 110000 ks and its getting worse. It looks like it will cost about 2 to 3k to fix or replace with a second hand one. Any thoughts or advise will be greatly appreciated. Thankyou
is this a manual trans?
if so that is usually a trashed bearing...one shaft can move a tad in a way it shouldn't which can slide the lock collar off the dogs enough to force it off.
synchros are usually a problem getting into gear, not popping off after so much.
consider finding a good scrapyard if this is the case. i was able to get my car done with this problem for $1k CAN (about $500 for the trans, $500 for install). not sure how that translates to oz cash.
