Anyone know what the correct oil capacity is for a 2021 Limited with 2.5 turbo? I am getting a lot of conflicting information.
thanks
2021 Phantom Black Sonata; 2009 Audi A6 Condor Grey
Have you checked the myhyundai online owners app?? It will tell you exactly with grade/type oil and capacity
Did the vehicle come with an owner's manual? All the capacities are listed within.
thanks
On page 2-12 of the Owner's Manual it says that both the 2.5 and 2.5T need 6.13 US qt. for a drain and refill.
Full synthetic API SN PLUS (or above), ILSAC GF-6, or ACEA A5/B5 is specified. If a lower grade engine oil (mineral oil including semi-synthetic or synthetic blend) is used, then the engine oil and engine oil filter must be replaced as indicated for severe maintenance condition.
Refer to page 2-14 for the recommended viscosity level of the oil. For the 2.5T, they recommend 0W-30, but you could use 5W-30 Full Synthetic unless you are in a very cold climate. Most Walmart's sell Mobil 1 0W-30. Do not use a "European Formula" 0W-30 (it will say that on the label).
All references are from the PDF version of the manual, which was downloaded from the Hyundai website.
