Maybe because I typically don't have my music app running on my (Android) phone but connecting it doesn't cut out sirius radio.Using android auto while listening to XM, or radio is a pain, it always wants to start playing audio from AA instead of giving me the choice. You have to go through a not obvious set of keys.
Mine works great! "Call <name>" works every time. "Go work" works every time. "Find address in Florida" followed by the address has worked every time. "Find Starbucks" always works.Voice commands in blue link are about useless, almost never work, Simple things like make a call etc.
What are 'hills'? I'm in Florida.The cruise control calibration is off. It is way to aggressive on trying to control speed on down hills. It slows down too much.
Hm, i didn't even know it had a way to go the speed limit, i just use SCC with a speed i set. You probably know but holding the speed lever on the wheel makes it go up or down 5mph. Works great.Auto speed in cruise, totally useless since it only allows the speed limit to be set. At least in MO it is pretty unsafe to run the speed limit on the highway. The auto speed should allow a speed limit + something (9 for me). Ford does that.
EPA ratings are not at 80mph.A super bummer for me is the mileage, nowhere near the rated mileage. I bought the car because it was supposed to get 28 on the Hwy. If I drive super conservative I might get 25. In normal driving it is usually down in the 22's with mostly highway driving. Very very speed sensitive, 60 to 80 is a very big difference.
If you use the LFA (lower left button on right side of wheel) it makes LKA noticeably more accurate.Inconsistent behavior when the LKA assist gives up. Sometimes it will chime and other times it will turn off and start drifting with no notice to the driver. It should really give you the option of being alerted when it is going to give up. I would make it optional so you have a choice. This behavior without the HUD would be much worse, with the HUD at least you get a visual indication that LKA is checking out.
Maybe a dumb thought but maybe there was dirt on the radar sensor?The wife was driving it early on when it started losing power, ended up doing 35 on the hwy. Called me in a panic, car has a mind of it's own yada yada, No warnings of any kind were displayed. She starts yelling I want my old simple santa fe back. Had her shut the car down and restart it, a reboot (I'm in IT). That fixed it. Brought it to the dealer, found nothing, a bit disconcerting, it has not reoccurred.
