Sounds like they're retaliating for the 1star reviewYikes! Why so long??
They wanted to keep it while they wait for the parts. But they never provided an ETA. I just assumed it was because they would get them within a reasonable amount of time. They did provide a 2020 Elantra as a loner though and they said I didn't have to refill the gas. So I guess I can look at it as saving money from that perspective. I'm going to call them this week and see where they're at since I'm starting to get close to a quarter tank now.Yikes! Why so long??
Well if that's the case then they'll get another one haha.Sounds like they're retaliating for the 1star review![]()
I hope they're not taking it for a drive like the parking lot attendants from "Ferris Bueller's Day Off"They wanted to keep it while they wait for the parts. But they never provided an ETA. I just assumed it was because they would get them within a reasonable amount of time. They did provide a 2020 Elantra as a loner though and they said I didn't have to refill the gas. So I guess I can look at it as saving money from that perspective. I'm going to call them this week and see where they're at since I'm starting to get close to a quarter tank now.
Lol. I sure hope not. I actually got an email from them about 20 minutes ago saying it would be ready by the end of today. Fingers crossed!I hope they're not taking it for a drive like the parking lot attendants from "Ferris Bueller's Day Off"![]()
Hah. Neighbors will think I'm crazy, but I just took my car out of the garage for awhile. Wonder how long I'll need to let it soak to get a good idea of my car has this problem.TS Fay is coming through our state today. Heavy rain and wind all day long. It should provide a good test to see if any water is retained afterwards.
Just tell your neighbors you're taking advantage of the free car wash.Hah. Neighbors will think I'm crazy, but I just took my car out of the garage for awhile. Wonder how long I'll need to let it soak to get a good idea of my car has this problem.
I concur with this assessment 100%. I have two 2020 Sonata SEL's/w Convenience Pkg. Identical cars except for color. One was purchased in January 2020 (White) and the other August 2020 Portofino Gray). The white one has the rear door drain problem on both rear doors with the rear driver door being the worst and passenger rear door minimal. The gray one has zero drain problems even after hard driving rain. The only difference I can see is the drain holes in the rubber door gasket appear to be pinched thereby not allowing proper drainage on the doors that have the drain problem. It is almost like the drain holes are not in the right place on the doors that don't drain properly or the gasket was not installed properly.My sonata limited had the door drain problem on the rear driver door only and after looking and comparing the gasket in the passenger side, it looks like the drain holes are in a different position. I was able to use a small set of scissors to make the drain holes slightly bigger which has solved the issue.
so replacing the chrome/rubber trim at the bottom of the window glass reduced the amount of water getting in? I’ve been looking at the strip on mine but it looks identical on both sides. I only have the problem on the rear driver door.UPDATE: We had torrents of rain yesterday, sometimes horizontal. I checked this morning and no water was retained in the rear door! Looks like the problem is fixed.
Did that same part fix the wind noise or was it something different they did? I have had the wind noise issue as well.Looks like the part 83210-L1000 seemed to do the trick. Instead of 2 cups of water pouring out after a heavy rain, now much less. Much improved(but not bone dry). That's two hits for Hyundai: #1 fix for wind noise issue and #2 for the water issue. Even more satisfied with the vehicle now.
No, just the water issue.Did that same part fix the wind noise or was it something different they did? I have had the wind noise issue as well.
So my next question is you mentioned the wind issue being fixed. Do you know how they fixed that? Thanks for any help you can give.No, just the water issue.
I had two separate wind issues. If you search the forum, you will find the threads and the parts needed for the fix.So my next question is you mentioned the wind issue being fixed. Do you know how they fixed that? Thanks for any help you can give.
