HVAC: When in AUTO mode only the temperature is displayed. You do not know if the AC is engaged, the direction of airflow or the fan speed. This info should be displayed in AUTO and the AUTO button should be lit along with the AC button when it is engaged. Any manual changes to the system other than temperature (fan speed, mode) should be displayed and the AUTO button light should then turn off.
Currently nothing is displayed unless you change the system manually. You also must press the AC button once to either engage it (or light the button if it is already engaged) then press it again to turn AC off.
Very poor design.
Very poor design.
