1 - 1 of 1 Posts
For those who want to change Sun Visor festoon bulb to LED festoon on 2017 Sonata, will be same for 2016 and 2015 models and possibly others as well.
The metal clip that holds light assembly in place is on the outside, you can use flat tool without sharp edges and push in and gently pull down, I used one from "Trim removal tool kit" by Sunplustrade. Be sure to push in black end down to remove light assembly from wire plug but do not pull too hard. Adjust new festoon LED, 30mm long, push it in and enjoy it :).
1 - 1 of 1 Posts
