Hi,
I bought used 2016 Hyundai Sonata plugin early last week. It ha been working great until recently. Wondering if anyone has seen this charging issue before. Sorry for length wanted to get all the details in.
Charge at 120V. Normally don't use schedule at all, just plug and charge
Tuesday morning noticed it hadn't charged at all, car started in HEV mode
Monday was the first day I had let it actually use all charge on way home, forcing it to switch to HEV
Drove HEV charge mode to work, car said it gained 6 miles electric range at end
When starting car going home it said I actually had 15 miles electric range
Drove home leaving about 10 electric miles range left
Plugged in about 3:30, said 50%. Green light on, power supply charge light on. Said about 5 hours to charge.
Glanced around 4:30, green light still on
Checked car at 6:00. Green light off, power supply charge light off. Still at 50%, so it wasn't charging at all even when green light was on.
Pulled plug from car and put back in, Green light goes on, power supply charge light goes on
Checked car at 7:45. Green light off, power supply charge light off. Still at 50%
Set schedule turn-on at 7:50. It did turn on at that time
Checked morning 4:45. It had charged to 70% but still shut off early. Good at least it does charge a little so power supply seems good. Said about 3 hours to charge.
Set schedule turn-on at 4:50. It did turn on at that time
Checked 6:10. Not charging, still at 70%. Turned off schedule and started "charging"
Went to work 6:40. Green light on, power supply charge light on. Actually decreased to 67%.
Notes
Started getting colder here. About 15-20, so not super cold but colder than last week
Again, Monday first time I had let it actually deplete electric charge and force it to switch to HEV
Anyone see anything like this? The car is still under MFG warranty so I may take it in. Also may try a L2 charger if I can find one.
Thanks
Notes
Thanks
