1 - 9 of 9 Posts
As I was driving on the highway in early August, the check HEV system warning light came on, then check engine and other warning lights as well.. As I tried to get off the road I started losing engine power and the AC shut off. The hybrid battery charge appeared to be over 3/4; I had never seen it that high. Had the vehicle towed to the dealership; they were unable to duplicate the problem after driving the car for 150 miles. The only diagnostic indicator showed that at some point in time the hybrid battery had overheated -- codes P0A7E and P1B97 are on my invoice. Since the dealership was unable to repeat the problem, they released the car back to me. Both the dealership and Hyundai refuse to do anything further, such as replace the hybrid battery system or the cooling fans, although the car has 58,000 miles on it and is still under warranty. I don't know if, unlike other folks with similar problems, the car would have started if I had just waited long enough. But honestly I don't want to find out and I no longer feel confident in driving the car. Any advice from others on getting Hyundai's attention and finding a solution? I really like the car and have not had any problems with it until this happened. Thanks!
The good news is that you brought it in and have it documented and with the codes. Ya, that is super frustrating! When is the next occurrence going to be? Like you said, it may have restarted after some amount of time (which is good in case you're not able to get it towed or to a shop readily). Two more times and you can get them to buy it back I guess... Hopefully someone else has a solution. It could be as simple as some switches and relays, not a battery or electric motor issue.
Did you know that the air inlet vents for battery cooling are under the back seat? Look at the vertical part of the seat. If you had stuff piled on the rear floor you could have blocked the vents. Or a rear seat passenger could have put their monstrous purse in front of the vent...
That may be a contributing factor. With many of these batteries being damaged from heat the manufacturers maybe trying to play it safe.
Discussion Starter #8
Well, it happened again a couple of days ago...my 2016 hybrid left me on the side of the road with the "Check Hybrid System" and all other warning lights illuminated. Car would not start for about 15 minutes, but when it did I was luckily able to drive it to the nearest Hyundai dealership. They are telling me that the power relay switch needs to be replaced. In this forum I'm seeing this as a recent common "fix" for this issue. Has this addressed the problem for other hybrid drivers? Or are dealerships just guessing that this is the problem? I know I should not be so skeptical but after having gotten the run-around the first time I'm just not confident in the dealership's ability to solve this. Thanks.
The Relay Fix should be a sticky as it is very common. Even under warranty still, I'm tempted to buy and have one of these on hand... Because it is not a matter of if, but when it seems.
1 - 9 of 9 Posts
