1 - 10 of 10 Posts
Hello,
Does anyone know the factory spark plug Gap for this car? The owner's manual is very vague and only says iridium coated plugs are needed.
I managed to find some Champion spark plugs :sick: and have installed them to .031" gap, but I would like to know the official Hyundai spec. One of the NGK plugs that I've removed had a .025" gap!
Hello,
Wow, you must really be putting on the miles to be changing spark plugs on a 2016 model. Aren't the factory ones good for 100k + miles?
It's only got 84k miles on it, but since I'm doing city miles I figured it's better to replace them a bit sooner than later.
They actually looked pretty good with all of them having a .031" gap except for one of them. I kept them just in case the Champion plugs decide to go bad on me. Now onto changing out the transmission fluid!
Just a word of caution. Definitely hold onto those original plugs since there are many forum threads on the HF site with tales of bad results using any brand/type of plug other than the OEM Iridium factory plugs in these later model year vehicles.
2012 Sonata Hybrid: Denso Long Life Iridium coated, exactly like the original ones, and no problem. Don't cheap out on the plugs.
Discussion Starter #7
Noted, however the only aftermarket plugs available were the Champion plugs. They're easy enough to change back if they start giving me problems.
1 - 10 of 10 Posts
