1 - 20 of 21 Posts
Started last week, wife would go out in the morning to start the car and it would display a warning light, check engine light and sometimes a random system failure. After pushing the start button several times, it starts and drives normally. Check engine and malfunction indicator light goes out after 3 restarts. I checked and it throwing a P1990 code.
60k miles. Not sure if warranty will cover this.
Any ideas before I take it to dealer?
thanks
The P1990 code is mentioned in a couple of the posts in the following thread. Seems the Power Relay Assy (PRA) and Electric Oil Pump are common failure items and gives the errors / conditions you are presently experiencing.
2016 Sonata Hybrid Limited - Check Hybrid System issue
Yes, I read through those posts too. This one seems to throw the code after it sits during the night. Wife drives home from work, about 20 min drive, and the car sits for the night. The next morning it gives a hybid malfunction error and check engine light comes on.
I wonder how hard it is to change those out at home and how safe considering the hybrid battery.
Thanks
Thanks
Turns out they found more codes at the dealer. They have ordered a hybrid control module.
Thanks for the update. What more codes were found? You're at the 5/60 mark it seems, is this under warranty?
I havent been told the codes yet. Still waiting on part to arrive. So far they are covering under they hybrid warranty. All they have told me is that the Hybrid control unit is not communicating with the other modules.
Did they give you a loaner/rental car while you wait for the parts to come in and then be installed and hopefully all work out and resolve?
Discussion Starter #8
They attempted to get a loaner. I was going out of town on Sat so no reason to get one to sit in the garage. When we got back into town on Mon the rental co didnt have anything available until Tues. We got the car back Tues afternoon. So no rental.
Codes were U0105-U0110.
Warranty covered replacement of the Hybrid Control Module. Cost was over $3k. I guess most of it was for labor and troubleshooting. The module should have been less than $1k from what I saw on parts sites.
You're the original owner right? Is this Hybrid part of the warranty under the 5/60 or 10/100? Because you said you were at the 60K mark. I got lots of questions because I can see this issue and other things I've read popping up of short or longer term as problems that are not cheap obviously.
It depends. Some of the hybrid pieces-parts are also covered under the emissions warranty for subsequent owners. Others show the hybrid system, except battery for non-original owners, are covered for the 10/100. Excerpts from the 2020 warranty guide:
8-YEAR/80,000-MILE
FEDERAL EMISSION DEFECT AND PERFORMANCE WARRANTY
Covers repair or replacement of the following original Hyundai major emissions control components that may cause the vehicle to fail to conform to an applicable EPA-approved inspection/maintenance program:
• Catalytic Converter
• Engine Control Module
• Onboard Emissions Diagnostic Device (OBD-II)
Other EPA (Environmental Protection Agency) emissions warranty parts are covered under the 5-Year/60,000-Mile New Vehicle Limited Warranty.
For 2020 Elantra and 2020 Sonata certified as a super ultra low emission vehicle (SULEV), 2020 Sonata Plug-in Hybrid, and 2020 Ioniq Plug-in Hybrid model certified as a transitional zero-emission vehicles, (TZEV) only, all parts covered under the PERFORMANCE WARRANTY and the DEFECT WARRANTY, which are listed in this Owner's Handbook on the Emission Warranty Parts List, are warranted for 15 years or 150,000 (excluding the Plug-in Hybrid Battery) whichever occurs first (for the states listed under the Warranty Jurisdiction (on page 39), See page 40, NOTE4.
Discussion Starter #11
Yes original owner. SM said it was the hybrid warranty that covered it.
I just hope my stuff goes out before 10/100 then because it seems like a matter of time before certain known hardware and parts go out... I have a CPO so other than the battery, like the original owner with full warranty...
thanks
This exact same thing happened to me, same code P1990. I'm driving a 2017 Sonata Hybrid Limited with 24,000 miles. I went to start up the car and got one of those triangle warnings that there was a issue with the HEV and do not start the car. I let the car sit for 5 min and it restarted but with the engine light still on.
Took it into the dealer and they replaced the Power relay Assembly. Everything covered. Free rental also.
Discussion Starter #14
Update:
Its started failing again. This last time, it wont start, shows hybrid error, error stays on then then it says brake failure and to pull over. Umm not going anywhere because you wont start. Then lights start flashing and says key not recognized.
Ugh. It's dead.
Waiting on tow truck to haul it back to dealer.
Hope you can get a full list of codes and find the root cause this time. Shouldn't have such issues with a new car let alone all ready been back to the dealer/experts.
Thats what I was going to say is the issue. Seems like the MOST common in all these Hybrids. Its under warranty.
Discussion Starter #18
Update
Car still at dealer. Power Relay replaced but car still wont start. Instrument panel lights up now, but the center piece shows gibberish where it used to show hybrid error. Dealer is working with engineering but they are at a loss to whats wrong. Service manager arranged for a rental last night. He couldnt get auth from Hyundai but went ahead and made a local decision. I appreciated him doing that for us. PR is covered under a recall he told us so no cost there. I hope it also covers the towing. But they are trying to figure out if the PR somehow shorted out the display. Still doesnt explain why it wont start. 62k miles so out of regular warranty. This could get expensive.
Discussion Starter #19
Got my car back today finally. Replaced the Power Relay and the Instrument panel. They said the PR shorted the instrument panel when it went out. They did not reset the odometer on the new instrument panel. But taped a piece of paper on the door sill with the old mileage. Sounds like a hokey resolution but service advisor said he had no way of updating the new cluster.
No payment for towing either. Said Hyundai wont pay for towing even if under warranty. The instrument panel cluster was almost $1500 for the part. So, I guess paying for towing is better than paying for the part.
That makes no sense that they pay for warranty but not towing. I would be arguing about that regardless of the rest like they'er doing you some favor by fixing their obligations? Interesting the PR took out the instrument panel that is unique and odd.
1 - 20 of 21 Posts
