21 - 26 of 26 Posts
I bought the car at a Hyundai dealership, used. I just hit 45K.
My car was pulling left very noticeably. I got my alignment done at a local Hyundai dealership, and now it pulls right. The tech stated this is "road crown pull"...the alignment was brought within specs (green all around), and my tire wear is even all the way around. :confused:
If the tires are wearing fine and are properly inflated it probably is the crown. You can check that by driving in the fast land on the freeway. Usually crowns to the left.
Hit 60K on my Equus. Took her to my indy for trans pan/filter replacement. He was able to drain/fill just under 7qts of fluid. There is a noticeable improvement in shift quality. I recommend it.
If I still have the car at 120K, I'll do it again.
Drain not flush, correct?
21 - 26 of 26 Posts
