Please can someone advise me on this one ☝
My car got automatic transmission only engaging
Gear number 2 / 4 / 6 & Reverse
The car won’t select gear - 1 /3/5 & 7
Which l assume they are the high gears
In case you're not aware you have a DCT so it's an automated manual gearbox.
One shaft / clutch will be 2,4,6,R, and the other 1-3-5-7
The clutches will wear out just like a conventional manual. You'd need to find someone with a diagnostic tool that can communicate with that system I think to see what's happening, I 'd expect a fault code. I don't know much more on these. Maybe it's in failsafe due to a fault?
My i40 judders when setting of from cold its a automatic gear box
My i40 used to do the same when setting of but it never bothered me coz l was using the car local journeys. I would advise you to get the car checked out ASAP. Recon box are not cheap.
l been getting quotes for £2500 minimum to repair the gearbox. DCT transmission 🤦🏿‍♂️🤦🏿‍♂️
I have the similar problem. You posted 4 months ago. Can you please tell me what was wrong and how you fix it.
Thank you
