I need to change the radio of my 2015 Hyundai Accent and I can't find the color code of the stereo cables.
If anyone can help me I would be very grateful.
Thanks!
Chris
This page purports to show the 2015 Accent radio wiring:
http://www.modifiedlife.com/2015-hyundai-accent-radio-wiring-diagram/
I compared a few to my 2013 diagram. It seems to be the same. They both refer to 18- & 24-pin connectors:
443530
Connector A
No​
Terminal Description​
Condition​
Specified Condition​
A1​
Loudspeaker Rear Left+​
Needed connection to the car​
Analog output​
A2​
Loudspeaker Front Left+​
Analog output​
A3​
Loudspeaker Front Right+​
Analog output​
A4​
Loudspeaker Rear Right+​
Analog output​
A5​
A6​
A7​
A8​
Rheostat from vehicle +​
A9​
A10​
Loudspeaker Rear Left-​
Analog output​
A11​
Loudspeaker Front Left-​
Analog output​
A12​
Loudspeaker Front Right-​
Analog output​
A13​
Loudspeaker Rear Right-​
Analog output​
A14​
A15​
A16​
A17​
Rheostat from vehicle -​
A18​
Remote supply for motorised antenna​
Acc on​
9V ~ 18V​
Connector B
No​
Condition​
B1​
B2​
B3​
B4​
Steering Wheel Remote Control​
Steering Wheel switch pushed​
0.5V ~ 3V​
B5​
B6​
USB D+​
USB device is inserted​
3.2V ~ 3.45​
B7​
USB /iPod power​
USB/iPod device is inserted​
4.9V ~ 5.1V​
B8​
AUX Right Sound Signal​
External Auxiliary device is Audio playing​
A waveform synchronized with sound is output​
(At time of Aux jack use)​
B9​
AUX Reference Ground​
Always​
Below 1 ohm​
B10​
Bluetooth MIC+​
Input the Voice Signal via MIC​
A waveform synchronized with Voice data via MIC​
B11​
Accessory​
Engine switch on(ACC)​
11 ~ 14 V​
B12​
Battery​
Always​
11 ~ 14 V​
B13​
B14​
B15​
B16​
Speed Sensor Signal​
Engine switch on(IGN), car is moved slowly​
Approx. 5V Level Pulse Generation​
B17​
Steering Wheel Remote Control Gnd​
Always​
Below 1 ohm​
B18​
USB data line​
3.2V ~ 3.45​
B19​
iPod detection line​
GND​
B20​
AUX Signal Input Detect​
Auxiliary device is inserted​
0V(Low) → 5V(High)​
B21​
AUX Left Sound Signal​
B22​
Bluetooth MIC-​
B23​
B24​
Ground​
Always​
Below 1 ohm​
Connector A
No​
Condition​
A1​
Analog output​
A2​
Analog output​
A3​
Analog output​
A4​
Analog output​
A5​
A6​
A7​
A8​
A9​
A10​
Analog output​
A11​
Analog output​
A12​
Analog output​
A13​
Analog output​
A14​
A15​
A16​
A17​
A18​
Acc on​
9V ~ 18V​
Connector B
No​
Condition​
B1​
B2​
B3​
B4​
0.5V ~ 3V​
B5​
B6​
USB D+​
3.2V ~ 3.45​
B7​
USB /iPod power​
4.9V ~ 5.1V​
B8​
B9​
Always​
Below 1 ohm​
B10​
Bluetooth MIC+​
B11​
Accessory​
11 ~ 14 V​
B12​
Battery​
Always​
11 ~ 14 V​
B13​
B14​
B15​
B16​
B17​
Always​
Below 1 ohm​
B18​
USB data line​
3.2V ~ 3.45​
B19​
GND​
B20​
0V(Low) → 5V(High)​
B21​
B22​
Bluetooth MIC-​
B23​
B24​
Ground​
Always​
Below 1 ohm​
Thanks!!!! I will tell you how the installation went
