Hi All!
I changed the valve cover gasket on my wife's 2015 GT. To do so, had to remove the high pressure fuel pump. I "thought" I needed to take the fuel supply line AND the low pressure rubber hose off of it. Turns out I only needed to do the B-nut for the metal tube, however, that didn't stop me from yanking on the rubber quick disconnect hose fitting.
I don't remember what it used to look like, but I think that the gray plastic insert on the inside of the hose-end came out as I was pulling on it?
Request Please: Could someone confirm or take a picture of what theirs looks like? When you pop the hood, its on the back right of the engine case, just above spark plug #4. Also, any help on what tool I should use to cram this clip back into the hose end if that's the case, or know if it requires a replacement clip? Thanks in advance!
