Help;
There was a lot of damage done to the underside of the RH wheel well after a tire blew out. In addition to a service engine light we have the following warning illuminated:
ABS, EPS, TPMS, MIL, ESC & DBC
I've been under the car and can see the wires to the wheel and they look OK. The tire shop did not replace the TPMS sensor with a rubber one.
There must be a common reason why we get all of these warnings when the tire blew.
Thanks,
Robert Harker
Hello Robert :00000732:
It's impossible to say what the problem might be at this point. Since you've just had a tyre replaced, I'd suggest checking that the new tyre is the same size as the other three. Other than that though, you'll need to take the car to a garage and have the ABS scanned to see what trouble code has been logged. The trouble code will give you some indication of what the problem might be.
Scottie.
Help;
Thanks,
Robert Harker
Do complete fault code search of all onboard modules to find DTCs to indicate which circuits seen to be at fault.. with "CAN" tie everything together, fault in 1 will cut COMM with others due to bum info or circuit fault
