1 - 10 of 10 Posts
Hi all. This is my first post, and I am having an issue removing my tail light wiring harness. I purchased the replacement harness, but I cannot figure out how to remove the original harness. Does anyone know how to slide off the harness's white clip that is mounted to the car? (See photo attached).
You have to compress the tab(s) and pull apart.
I was talking about the small nub that is circled in this screenshot. I was not able to remove the harness from the tail light. So I ended up intentionally breaking off this nub to remove it, and that solved the problem just fine. It was just way more time consuming and complicated than it needed to be.
Hyundai sonata 11
May i ask, did u buy that cause ur brake light fuse kept blowing? Thats the problem im having and it shuts down the whole car
2013 sonata gls. Does anyone have intermittent power issues to the brake light harness itself? I bought replacement harnesses (L&R) im going to splice in but curious if this is a common problem?
1 - 10 of 10 Posts
