1 - 8 of 8 Posts
So my wife called me today and for the second time in about a week, she said while driving (cold engine) between 20-25 MPH the engine revs to 4500 RPM, drops immediately but the car does NOT lurch forward. This is a brand new engine (6000 miles on it). Also, to note, I replaced the battery about two weeks ago----could this change the shift points or affect it in any way?
Info----2014 SFS limited with 2.4L @ 122,500 miles.
I will check if there's a code when I get home because we have the check engine light on constantly due to a bad catalytic converter that probably happened during engine failure. Also, I don't know if this is coincidence, but the radio/console rebooted while she was driving to work as well.
Yep check ground, and check the battery terminal clamp too, they may be loose. You should not be able to move them around. When I replaced the batterie on mine, the terminal were staying loose even after over-torqueing the clamping nut and making sure the clamp was all the way down on the post. I had to put a battery post shim to have them clamp firmly.
A loose connection can cause many different intermittent and random issues.
Discussion Starter #7
Okay, the cable was not loose nor was it tight. I tightened it it's very snug and we'll see what happens. I did take it for a test drive this am as the temperature was a bit chilly. When I went from reverse (out of the driveway) to forward, I did notice the engine wanted to or expected a gear change and did rev a bit higher, but I did not step on the gas, I just let it pick up speed on its own---it's weird, I can't really explain it. However, after that it was fine. I guess it needs to warm up? I will report back in about a week....
1 - 8 of 8 Posts
