1 - 1 of 1 Posts
I had a question on my air conditioner system I hit a deer on June 1 it popped a hole in my condenser and leaked out I just installed anew one and install new refrigerant is the clutch suppose to run all the time? Is it suppose to disengage when fan sys is in off and all the ac button turned off and the heat system on? Right now the clutch on ac system is running every time I run the engine wether or not I have anything on or in off even when I press button from the cold to the heat I still see it engaged and running even before I filled system it was running what do I do about it how do I fix the problem or is it normal for it to run all time on these newer cars? The ac blows out nice cold air and works fine after i filled it
1 - 1 of 1 Posts
