Hey there I'm from the island of Barbados ??. I have a 2014 Elantra and recently it started acting up, it's hard start at times the sometimes starts as normal. When it hard starts some tachometer not work and electronic stability light is on or what we call traction light. Sometimes it stalls at idle. I got a scan did and it's says CPS pending also about throttle body. So I got throttle body clean and problem still there, rough idle, hard start or cutting out. I've ordered a CPS so I'll see when it's installed.
Good starting point. Cheap part, easy to replace and it has the code. They seem to be a problem on many cars. The wiring might be the cause so have a good look at the plug when you have it off.
