help me out the get de a/c wiring diagram, allready jump power to the a/c compressor and is working, allready check all fuses and they are ok, so need to check the wiring diagram to find the issue.
Plug in GDS,, head into engine data,, pick the 3 A/C lines,,, see static system pressure ( need 80 minimum),, look at request to PCM from HVAC control,, and PCM command A/C operation..
I dont even need to open hood,, all done from driver seat with GDS tablet
I suspect low R134,, look at discharge hose off compressor for moist/wet/ dirty hose, while other line there is dry and clean
