My car is making 16 loud beeps from behind the instrument panel. No dash warning lights or anything. Just the 16 beeps upon startup. Car runs fine otherwise.
It's time to take your car to the dealer for a diagnostic test. It may be serious. Better safe than sorry.
Do you have pushbutton start? If so, try taking the other key with you. Mysterious beeping when starting or shutting down the car is an "undocumented feature" that's warning you that the keyfob battery is low. The battery should be the standard CR2032 that they use on computer motherboards and you can buy them anywhere. Change out the battery and see if the beeping goes away.
