1 - 19 of 19 Posts
Hi every Elantra GT owner out there . I owned a 2014 Elantra GT since 2014 . The car comes with the tech package ( Leather , panoramic sunroof , premium stereo with NAV system...)
My car had the rear wheels handling issue and I took care of that back in 2014 by replaced them with the KYB shocks . That was the best $ 100 upgrade investment for my car because it totally transformed it and has given the car the driving confidence on the twisted and mountainous roads . As of 10/2019 my car has about 55K miles on the odometer .
I now have two issues and hope someone out there can give me a good advice .
First , to turn up a notch on the handling I would like to replace the front shocks with the good after-market shocks but there seem to be none available . Is there one made out there ?
Second , I going to need to replace the car battery ( the car is 5.5 years old ) but every shops I have inquired , they all followed the book and tried to sell me a phisically smaller battery H5 ( 650 CCA , 100 min reserve RC ) . But the H6 is phisically exact match to the OEM ( But is rated at 730 CCA instead of 600 CCA OEM stock , 115 RC ) and because the book calls for an H5 they can only install an H5 . the H6 is same size ( I took the measures ) and same polarity location . Should I get the H6 for a little extra robust capacity ? They both cost the same .
If I had the option of 2 batteries physically the same, same price but one had a greater capacity, I'd go for the lager capacity so long as it was as good a quality and warranty.
I'm running with purely 2014 GT Elantra, no other specs given and KYB site suggests these but also says available 3rd qtr. We have these available over here.
Maybe contact KYB and ask the question.
LHF 3340149
RHF 3340148
Rears 554384 ( gas- a - just) or Excel-G 349184
LHF 3340149
RHF 3340148
Thanks Gerard 2 . I has been waiting for these since 2014 .
A 730cca is a very big battery for a Elantra. I would think the smaller one is more than sufficient for your car.
If the physical size is the same but capacity is different look for the number of plates. There may be more plates to increase the capacity, if not then it is battery design or acid strength that will be the reason for the larger capacity.
I ran into the same thing when I changed the battery in my '14. The dealer literally would not sell me the H6 battery because it wasn't called out in the computer. After spending a few minutes trying to explain to the guy behind the counter that excess CCA would not hurt the car, that voltage and sufficient CCA were what mattered, I gave up and went down the road and bought an Interstate battery. Been in there for over a year, no issues. And the negative battery cable reaches without being stretched full length, as it did with the original battery.
I joked with a buddy that the Interstate H6 I put in there has so many cranking amps that if the starter ever locks up the whole car will just start rotating. :)
The CCA is very important for cranking purposes as well as passive current drain on modern cars but 730cca is a very big battery and will it last any longer than the lower one. I don't think so.
At issue here is that the freeze shield that comes with the vehicle is for an H6 size battery, not an H5. Also, the battery tray fits the H6. Will not fit the size of the H5 and could allow the battery to move side to side. Make sure the securing clamp is properly installed and tight.
are you sure about H6 being the std size?
for general interest, I just replaced my battery in my 2013 GT after 7 years ownership. The size bought (and recommended) was H5 and it fit perfectly the shield that went around it and the base tray clamp down. It also matched the old one size as well.
Decent battery for $109 CDN too
Kirkland Signature Automotive Battery (from Costco Canada)
Group Size: H5, Fitment Code 32 (I assume that has to do with the terminal positions)
Battery Specifications:
Cold Cranking Amps – 650
Cranking Amps – 810
Reserve Capacity – 100
Amp Hours – 54
Warranty:
0-48 months - Full refund based on purchase price
49-66 months - 50% refund based on purchase price
67-100 months - 25% refund based on purchase price (over 8 years of warranty coverage)
Yep, mine was an H6 originally, but at the cranking amps of the current H5. The dealer parts guy (not a technician) refused to sell me the H6 size higher cranking amp battery because his computer showed it had to be an H5 case. Never mind that I could show him what was in the vehicle, the computer is always right. :rolleyes:
I installed Interstate MTP-48/H6 730CCA. Which is interesting as Interstate's database also shows the car came with an H5 case size. I checked with the shop lead at the dealership and he indicated that the originals were H6 case size, H5 performance spec. Must be a Korean thing. Electrically, either will work. All originals on the '14 EGT sold in NA were flooded, not AGM.
And the battery for daughters '16 Elantra SE sedan is one of those AGM batteries and cost over $200, $260 at a dealer.
Part Number: MTP-48/H6
Group Size: H6
Cold Cranking Amps: 730
Cranking Amps: 910
(RC) Min @ 25 Amp: 115
Amp Hours (Ah) @ 20 Hr: 70
Length: 11
Width: 6 15/16
Height: 7 1/2
The "Tim Taylor" of Elantra GT batteries. :D
Cranking Amps – 810
Amp Hours – 54
Warranty:
did u get them to do the install at costco?
My '14 came with and H6 size battery from the factory. If I install the H5 the freeze wrap is much larger than the H5 and the ground side cable will just barely reach the negative post on the H5. The H6 fits perfectly and has higher CCA than the original battery. Not sure why this is, and especially why the dealer insists that the car came with an H5 battery when it clearly did not. The shop foreman says they have seen several EGT '14 and later with this confusion.
I will try to get a picture to better show why the H5 would be a problem in my car. Not electrically, but physically.
443234
As you can see, the battery fits the tray perfectly, and the freeze wrap is fitted to the H6. The problem with the H5 fitment for my '14 is that the smaller battery must be centered to the tray to allow both the positive and negative cables to reach the posts. It will fit, but both the positive and ground cables are at their limits with no strain relief. Look at the ground cable and you can see the issue.
H6 is the correct battery for the GT. H5 is for the sedan. When searching for part, you always see Elantra, sometimes Elantra GT or hatchback shows up as a subcategory or “option, or actually Elantra GT is shown as a model. If I cannot get a separate Elantra GT or subcategory, I assume the part is only for the sedan and no guarantee that it will fit the GT. The sedan and the hatchback are not the same model. Just look at this forum, my 2014 GT has the model designation as GD (2013-2017), the current Elantra GT (2018+) is model PD. The Elantra sedan (2017+) is model AD. The Elantra GT is known as the i30 outside of North America.
nope... took it home and did the install myself. took 20 minutes. I don't think my Costco does battery installs... they are strictly tires and oil changes as far as I know.
And fit perfectly.. same size as original battery... but sold as a H5 according to their fitment booklet and counter display.
I noticed after my dash selections for door locks and fuel economy settings reset when the battery was replaced.
1 - 19 of 19 Posts
