1 - 8 of 8 Posts
the headlamp being all the bulbs in that headlamp assembly (headlights,parking light,signal light)? or just the hi/low beam bulbs?
by "fire at progs" do you mean it has power (volts) at the prongs where it connects to bulb?
have you attempted swapping bulbs from one that does work into one that does not?
I'm sorry Yes I'm sorry the low beam the other Bulbs in that lamp work. All others in the entire headlamp work except my low beam bulb. I took the working ball from the other headlamp and put it in that is not working and it does not work in there either. I mean we're the prongs from the light bulb go into the connectors all of that is getting power But the bulb does not come on.
If you have power at the socket, and the bulb works elsewhere, then you have an installation issue or contact issue. Find someone competent to seat the bulb. Its not often but sometimes the socket needs replacing.
  • Like
Reactions: GsiTurbo
1 - 8 of 8 Posts
