It’s happened several times over the past 6 months. I open the door when not locked.., try and start but no lights on cluster and it won’t start. I open and close the car door and Shazam it lights up and starts. Today it was locked and I had to open with the key. I terries several times to open and close the door before I got power. It’s not the battery or connections. They’re fine.
2007 Honda CRV
Have you tried to clean the battery posts and cable terminals
Also follow the negative cable to chassis and clean up grounding point.
Have read ... the connections and battery are fine.
But, as Autospark said, obviously something is not fine.
You also did not mention anything you have tried other than open and close the door.
