1 - 12 of 12 Posts
Hi,
I am new to this forum and I am owning 2013 Hyundai elantra 4 doors, automatic transmission. 3 weeks ago I had an accident and part of the front bumper was damaged. However I found use bumper from eBay in really good shape but from the accident the wire harness for the ambient temperature sensor and the driver fog light are missing . I tray to buy it from the dealer but is to much($282). My request is if some one have 2013 elantra to take picture of this front bumper wire harness assembly and send me the pics so I can make my own harness. The wire harness start with 8 pins male connector which branches to more connectors, one is for the ambient temperature sensor and one is for the left fog light. I registered to Alldata but they don't have wire schematics for 2013 elantra. Thank you all in advance for your help.
Here are the pictures of the main, control and front harness from the Elantra GT. I can't find exactly what 8 pins connector you're talking about in these. If you can find exactly what connector you need I can send you the pinout.
The fog light is on the front harness. The A/C control module containing the ambient sensor is on the main harness.
https://googledrive.com/host/0B2XwV7ab33OAUnlXUUxPNlNCazA/main harness.png
https://googledrive.com/host/0B2XwV7ab33OAUnlXUUxPNlNCazA/front harness.png
https://googledrive.com/host/0B2XwV7ab33OAUnlXUUxPNlNCazA/control harness.png
Discussion Starter #7
The fog light is on the front harness. The A/C control module containing the ambient sensor is on the main harness.Thank you
TurboLed, I appreciate the you spend some time for my problem.
The attached pictures are to show where exactly the socket is located. The socket connector is for 8 pins but has only 6 wires( 2 black,1 red/purple, 1 green,1red and 1 blue wire). 2 of the wires are for the driver side fog light(require 12V), 2 for the horn(require 12V) and 2 wires for the ambient temperature sensor(require 5V). So this is the wire harness I am missing, its about 4 feet long with 4 socket connectors. Thank you again
Ok I think I found what you need. You are missing the "front-end harness" and the connector you are showing is the connection between the front-end harness and front harness.
Here are the connections for the front-end harness. There are 6 wires, 2 for the horns, 2 for the temp sensor, 1 for the external buzzer and 1 ground. There is nothing for the fog lights.
The fog lights connectors are part of the front harness.
Color code is as follow: B = black, L = blue, Gr = gray, G = green, O = orange
Remember this is from the Elantra GT as I don't have the schematics for the Elantra. There seems to be a color mismatch with what you gave me.
https://googledrive.com/host/0B2XwV7ab33OAUnlXUUxPNlNCazA/front end harness.png
When you buy your new bumper, make sure it has the hole in it so that your can insert a tow hook if needed. (this may not apply to your vehicle, but check it out anyway).
1 - 12 of 12 Posts
