1 - 20 of 44 Posts
So i tried multiple usb flash drives to play mp3 songs in the vehicle.
As a test, I tried 10 different make/model flash drives, formatted them with the different types and copied 4 folders consisting of 10 songs to each.
When i say doesn't work, means the radio resulted in the error message of "connection error". Here is what i found:
* Windows NTFS, MAC OS HGST and Windows FAT format doesn't work
* Lexar, Kngston, PNY and Centon flash drives don't work
* Patriot flash drives formatted with FAT32 works
* Sandisk flash drives formatted with FAT32 works
* Tested sizes were from 8gb to 32gb
Have not tested an external usb hd or a microsd card in a usb adapter. Right now i am using a 32gb sandisk with over 1000 songs on it.
I like to hear from others what make/model/size and format your using in your Elantra that does play mp3's properly.
Thanks
Thanks
In the cars manual it says to use FAT32.
I've used a Supertalent USB (8GB and 32GB) chip in there and had no problem. External USB hard drives will not work as they need more power than the USB port provides. A curious mod would be to supply the external HD with extra power and then hook it's USB data cable into the USB port.
It will play VBR and CBR mp3s. It uses the ID3V1 tag for the display on the radio head.
Playback is handled with music located at the root of a location (at the top of the drive or inside a sub-directory) of the USB stick is played first. Then the sub-directories second.
Songs are played in file name alphabetical order with numbers played first (Ex. 01-Mysong.mp3 is played first over Mysong.mp3). Then capitalized letters, then lower case letters. Example, songs labeled: N-Trance, n-Trance, and n-trance. N-Trance is played first. n-Trance is played second. n-trance is played third.
Here is another thread talking about this topic: http://www.hyundai-forums.com/231-md-2011-elantra/166777-portable-hard-drive-limit.html
My wife's GT has worked with every brand of flash drive I've thrown at it, all formatted FAT32, and all different sizes from 4Gb to 32Gb, with tunes encoded from 128Kb to 320Kb. I have an 32Gb iPod touch in mine so I don't need a flash drive.
I use a generic Micro Center 32GB USB3 thumb drive with a bit over 1000 songs and it works fine. That said, I have a real gripe about this head unit which is a huge oversight in my eyes. No proper playlist support, is really annoying. I heavily rely on custom playlists which I build in my music manager (Rhythmbox) and this head unit wants nothing of m3u or pls formatted playlists.
I was using an iPod touch before but has been nothing but a migraine since going back to Linux. So my solution to the playlist issue was to simply write a python program which takes my playlists from Rhythmbox and makes duplicate copies of all the songs, numbering them appropriately to maintain order, into a special directory for each individual playlist.
So in other words, the drive looks like this:
- All Music
-- all mp3's stored here
- Playlist 1
-- 001 - Song 1.mp3
-- 002 - Song 2.mp3
-- etc, ...
- Playlist 2
-- 001 - Song 1.mp3
-- etc, ...
Yes! I too find that annoying. Right now I just have them sorted out by rough genre and then sorted by artist name. So once I start listening to the 80's, I'm only listening to 80's until I get out of that folder.
I personally doubt they can come back with a firmware update to fix that. It might be something that needs a complete head re-design.
Retired Staff
Same here multiple random drives up to 32gb all worked fine.
Honestly, these formats are so simple, I wrote a complete parser class for the standard PLS format in under 30 lines of code. There's no excuse except pure laziness IMO.
has anyone noticed that the usb does not always go back the spot in the audio that you left off at when you shut the car off? I like to listen to audio books and the files are over an hour long at times. When I start the car back up it often takes me to a differnt point in the audio file, if not starting the file over all together.
If anyone knows if there is a fix to this, I would really appreciate it.
16GB PNY Micro Metal Attaché formatted FAT32 does NOT work.
Really bummed out!! A very cool little stick. see pics.
Does it have any security partition that could be interferes with it?
If you like small metal USB chips, Super Talent Pico-C has a nice 32GB which works nicely in the Elantra (Pico USB Flash Drives | Super Talent Technology). I don't have their 64GB one so I can't test that one. Also the SanDisk Cruzer fit are awesome and work (Cruzer Fit USB Flash Drive by SanDisk).
Hard Drive I use
Thanks
I use a 500 GB Hitachi Simple Tough external hard drive in my Santa Fe and 2013 Elantra
I'm running a 16gb Kingston DataTraveler SE9 with over 1500 songs, hasn't given me a bit of trouble. Which is more than I can say for a microSD card and holder - those tend to fry when left in the port.
What is it formatted to? I feel like most HDDs are formatted in a way that doesn't work in cars. What's the secret?
FAT32 most likely. Most of these car systems are behind the power ball, that is they lag behind the technology. Someday maybe we'll have solid NTFS support.
1 - 20 of 44 Posts
