Noticed last night driving behind Mrs. that the passenger mirror turn signal repeater is not working. Going to try to fix this myself today. Can't seem to figure out how to get the signal out of mirror housing. Then will need to find bulb to replace.
Thanks
Sent from my SM-G955U using Tapatalk
You might get a reply from someone who has replaced the mirror lamp on a 2013 Elantra if you posted in the correct forum for that model....link below.
On the Hyundai i30 (the UK version of the Elantra) you remove the mirror glass to access the screw that secures the turn signal lamp...see photo.
The lamps on UK models don't have replaceable bulbs though. They have LEDs, so you just replace the complete lamp unit. I suspect yours will be the same.
2011-2016 MD Elantra
i30 Mirror - Green Screw Secures The Lamp.
Remove the screw and slide the lamp outwards a little to release it from the mirror.
