Noticed this the other day. While in drive, (didn't do it in park at first) activated the right hand signal. Noticeable buzz. Popped hood and sound appeared to be coming from engine fuse box. Took it to dealer and they have ordered a multi switch that apparently goes in the steering column so I guess the buzz in the fuse box is just a reaction to whatever is failing in the steering column.
On a side note. Took the 2012 elantra ltd in today because we noticed one of the original brake pads (front passenger outer) was a different dimension that the driver side. The pad material extended beyond the rotor braking surface and at ~40k the pad now has a noticeable knub extending on the inside part of the rotor in the groove between the shiny metal rotor and the studs.
Tech first said it was an aftermarket pad but we've never had service done to the brakes, only service at this dealer or at home. Later another tech apparently indicated this is a kia brake pad. How it got on the one side is a mystery! We have wheel locks. The car was bought new from this dealer but was a dealer trade so the only break in possession between the factory and us is the other dealer. Will be interested to see how Hyundai Canada or the district rep respond to this, but the dealer installed new pads (didn't turn the rotors) at their cost cuz they said they can't put it thru warranty.
Just noticed an additional symptom that may or may not have been occurring with the buzzing upon activating the right hand signal. The high beam seems to activate at the same time. Not always repeatable but it is definitely not because the stalk is being pushed forward. Probably just another symptom of the defective multi switch going.
