New development with my car, when driving in any mode (eco/non/techtronic/awd lock) the vehicle will lurch hard and cut power for a second around 4k rpm or Im assuming near peak boost. It doesn't appear to be transmission or driveline related as I mentioned I tested it when controlling the shifting and the AWD myself. The engine has had the campaign replacement already. Otherwise engine runs/idles smoothly.
Any thoughts on the cause?
2013 Hyundai Santa Fe
Sohnds like a misfire. It's likely an ignition coil breaking down under hard load. Need to monitor misfire data while experiencing the condition so you can determine which cylinder.
