Hi all,
I've got a 2012 Tucson GLS AWD with 191,000km on it and the airbag light just came on. I checked the codes and got a "B1334 PFIS to SRSCM Communication Error". I removed the Front impact sensors from the rad support and inspected, swapped the passenger side to the drivers side and vice versa to see if the trouble followed the passenger side sensor which it looks like it didn't. I cleared codes, rescanned and got the same B1334 code again. This would indicate that the sensors are fine and the trouble would be with the wiring or the SRS control module. Would anyone be aware of an issue with the wiring or control module that might be able to point me in the right direction?
Thanks in advance
Dan
Thanks in advance
Dan
