A few weeks ago my stereo system completely shut off mid drive so i had reset it once i got home and everything was fine. I got back into my car the following day and it had completely shut down on me along with the charging ports.
before it had shut off the first time i took my charger out of the port and it caused the stereo system to flash on and off before shutting off completely i have already replaced the multimedia fuse and still nothing
Has anyone else gone through something similar? How can this be helped and what would the price range be to get it fixed?
Switch the ignition on then use a voltmeter to check ALL the fuses by probing the little test terminals on top of each fuse. When you find a fuse that has 12V on one of it's terminals but something less on the other that'll probably be the one that's causing your problem.
