Just got a used 2012 GLS and found that none of the power sockets are working.
Found that the cig lighter was just rusted up inside, so got that fixed.
But the accessory socket (which is very clean) is not working. Neither is the one for the passengers, which I assume is on the same circuit.
Checking voltage at the fuse box (with key set to ON) I get 12 for the cig lighter and .01 for the power outlet. Checked a few times, definitely not zero, but .01 - .02v. Fuses are fine.
Where do I go from here?
