Have anyone experienced - diesel fuel mixing with oil causing the oil level to rise? Aisde from rising oil level, engine emits black smoke. My mechanic initially guessed that it is from the busted oil seal of the high pressure fuel pump but after replacing the oil seal, problem still persists. Any input or recommendation/s is welcome.
This has been talked about a lot. Do a seach.
00000732
Best practices for requesting help:If you haven't done so fill in your vehicle info and profile page. At upper right corner under the search box click on user cp (it's your control panel)
This info will show up to the left under your user name and is very helpful.
BE SURE TO ADD YOUR LOCATION SO WE KNOW WHAT MARKET YOU ARE IN.
  • Be sure you are in the correct forum for your vehicle.
  • Do a search for your problem. A lot of stuff has been asked and answered.
  • Do not double post for the same problem.
  • Give the model year....Engine size...transmission type (auto or standard)
  • Take a single issue at a time. Posting multiple issues at once will get convoluted very quickly
  • VIN number can be very helpful
  • Vehicle history can be good. How many miles. If not bought new, how many have you put on it.
  • Describe the problem best you can. If a noise can you get a sound or video file
  • Tell us what has been done, if anything, thus far. If tests have been performed give actual results not OK or passed. If scanned for codes the actual code(s) not O2 sensor or MAF, Etc.
  • If the vehicle has been to a repair facility it would be nice if you could post a picture of that invoice/bill
  • If your vehicle is under warranty you should have the dealer check it out. If it's a problem they see many times they will generate a safety recall of TSB. This is how they know of the problem.
Thanks,
Welcome aboard.
