2012 Hyundai Elantra Limited
Hey, Guys, girlfriend has an 2012 Elantra Limited with 162k miles.
Recently, it has started to hesitate or cough at around 30-35 mph, the battery light will blink, starts right back as if nothing has happened. No codes, new battery, new alternator, mechanic rode around in it with a scanner, no issues with fuel or MAP, cleaned the throttle body, relearned the TB. everything else is fine. Weird part is, it doesn't do it all that often, but the girlfriend is worried.
Any Ideas?
Did check them, and got to thinking, if that was an issue, I'd have issues starting as well.
Anyway, found the ground for the engine on the back left side, and the battery ground on the right side.
Both looked good, but lossened them and re-tightened, while I changed the spark plugs.
remove the paint under the ground to bare metal. Apply dielectric grease and re-secure the ground bolt.
