Alright guy im going to tackle replacing the motor in this car what should I be aware of and will it have to come out from underneath car or is their a way to pull it up top? Thanks
I've managed with this setup, can be challenging as you need to angle the trans down to get the package out. Bonnet needs to come off. And I think due to height I had to have the vehicle on the deck to get the height. Worked for my Diesel Sonata where the motor is almost to the rail and part of the trans sat under the rail on the other side. From underneath would be the way to go if you can achieve it
443528
The donor removed, manual trans.
443529
