Hi,
My model has an 6-speed automatic with a semi-automatic shiftier on it. I was trying it out the other day but I noticed a problem (or operator error) that I believe to be with the overdrive. An example is when I hit about 3,000 RPM in 3rd or 4th gear the overdrive kicks in and drops it to 1,500-2,000 RPM on its own before I can shift.
My issue with that is the overdrive kicks on and off based on my throttle response. So If I'm in stop and go traffic as an example the RPM is all over the place while it turns on and off over and over again.
Is there anyway to disable overdrive on this model?
Thanks,
Derek R.
Thanks,
Derek R.
