Everyone,
The Fuel door cable has stopped functioning on our 2012 Elantra.
Does anyone have information on how to replace it and or open the fuel door without force able entry?
This model does not have an emergency cable in the trunk.
Thanks
You might want to post your question in the Elantra forum. It might get answered more quickly there.
Hey there, its pretty hard to see but it should be located on the left side (whatever side your fuel door is on). it will be quite hard to see from inside the trunk but there should be a moulding piece (could match fabric of trunk or be plastic) that can be removed and the fuel door opening would be accessable through there. For a fix it depends on if it is the cable from the pulley on the floor or if it is the cable to actually release the door at the back.
Hope this helps!
