TSB (technical service bulletin) 10-EM-004 ... just noticed this one effective for October 2010.
It appears that the 2.0T 2011 Sonata's require a new Turbocharger Oil Feed Pipe.
Does anyone have more details regarding such, what is wrong with the current configuration?
Please see the attached .pdf document "2011 SONATA TURBO TSB - 10-EM-004.pdf"
Old news, all cars are done and current production cars have the new part... it is not something the end consumer is going to swap themself..
We had 2 at our place we did.
Only thing I could see was the addition of a tube over the short rubber section to protect it from radiant heat..
Refer to topic here ----> http://www.hyundai-forums.com/t54496-hyund...turbos-1026.htm
QUOTE (sbr711 @ Nov 10 2010, 06:47 PM) index.php?act=findpost&pid=370656
Thanks, I did search the forum first so I wouldn't waste anyone's time. I obviously didn't query the correct verbiage. Thanks,
Prepare to get moved to another (lame) section.
Exactly. Forget that it's 90% the same car. You get your own section. Resources better sent elsewhere.
